Customizing menus
Corel customization features let you modify the menu bar and the menus it contains. You can change the order of menus and menu commands; add, remove, and rename menus and menu commands. You can search for a menu command if you do not remember the menu in which it belongs. You can also reset menus to the default setting.
The customization options apply to the menu bar menus as well as to shortcut menus that you access by right-clicking.
Help topics are based on the application’s default settings. When you customize menus and menu commands, the Help topics associated with them do not reflect your changes.
To change the order of menus and menu commands Back to Top
To rename a menu or menu command Back to Top
An ampersand (&) before a letter in the Caption box indicates a shortcut, also known as a mneumonic accelerator key. Menus are displayed by pressing Alt + the letter. Commands are invoked by pressing the letter that is underlined when the menu is displayed.
You can reset the name to the default by clicking Restore defaults.
To add or remove an item on the menu bar Back to Top
To add or remove a command on a menu Back to Top
To find a menu command quickly Back to Top
To reset menus to the default setting Back to Top
