| • | To draw a polygon |
| • | To draw a star |
| • | To reshape a polygon |
| • | To modify a star |
Corel DESIGNER lets you draw polygons and two types of stars: perfect and complex. You can draw polygons and stars and then reshape them. For example, you can convert a polygon to a star by dragging its nodes, and you can change the number of sides on a polygon.
You can also draw a predefined star shape. For more information, see To draw a predefined shape.
| To draw a polygon |
| 1 . | Click the Center-point polygon tool |
| 2 . | Point to where you want the center, and drag in the drawing window until the polygon is the size you want. |
Example of using a polygon to create a nut
You can change a polygon to a star by selecting the polygon with the Shape tool, clicking a node on one of the sides, and dragging toward the center of the polygon.
| To draw a star |
In the toolbox, click the Star tool
In the toolbox, click the Complex star tool
Click the Shape tool
Select a polygon. Type a value in the Points or sides box on the property bar, and press Enter.
| To modify a star |
Select a star, type a value in the Points or sides box on the property bar, and press Enter.
Select a star, click the Shape tool
When you use the Shape tool to reshape a perfect star, the node movement is constrained. Also, you cannot add or delete nodes, or convert line segments to curves.
