When publishing a document or selection to the World Wide Web, you can choose several options, such as image format, HTML layout, export range, and file transfer protocol (FTP) site parameters.
1 . |
Click File Export for HTML. |
General — contains options for HTML layout, folders for HTML file and images, and FTP site and export range. You can also select, add, and remove presets. |
Details — contains details of HTML files produced, and allows you to change the page name and file name |
Images — lists all images for the current HTML export. You can set individual objects to JPEG, GIF, and PNG formats. Click Options to select presets for each image type. |
Summary — shows statistics for files according to various download speeds |
Issues — displays a list of potential issues, including explanations, suggestions, and tips |
Corel DESIGNER assigns the extension .htm to documents you publish in the HTML format. By default, HTML files share the same name as the Corel DESIGNER (DES) source file and are saved in the last folder you used to store exported web documents.
