You can add colored, patterned, textured, and other fills to the inside of objects. You can customize a fill and set it as a default, so that each object you draw has the same fill.
This section contains the following topics:
| • | Applying uniform fills |
| • | Applying fountain fills |
| • | Applying hatch fills |
| • | Applying pattern fills |
| • | Applying texture fills |
| • | Applying PostScript fills |
| • | Applying mesh fills |
| • | Applying fills to areas |
| • | Working with fills |
