| • | To turn gravity snapping on or off |
| • | To use gravity snapping |
| • | To set gravity options |
The gravity field of each snap point has a radius of 10 screen pixels (not document pixels) by default. When the pointer enters a gravity field, a gravity source indicator appears around the point, and the name of the gravity source appears on the screen. You can turn gravity snapping on and off.
Gravity shortcut keys let you activate a single type of gravity snap. By default, gravity shortcut keys are the first letters in the names of gravity-snapping candidates. When you hold down a gravity shortcut key, all other gravity snap points become inactive. For example, if you hold down the M key, only the Midpoint gravity snap point is active.
Corel DESIGNER lets you control how gravity snapping works.
| 1 . | Click Tools |
| 2 . | Enable or disable the Gravity on check box. |
You can also toggle gravity snapping on and off by pressing Alt + Z.
| 1 . | Move the pointer close to where you want to snap. |
| 2 . | Click when the gravity source becomes highlighted. |
| If you are dragging to draw a line or select an object, release the mouse button. |
To turn off snapping to guidelines, click Tools
| 1 . | Click Tools |
| 2 . | Perform one or more tasks from the following table. |
Enable the Snap to page check box.
In the Modes area, enable the corresponding check box.
Click Select all.
Click Deselect all.
Enable the Show gravity location marks check box.
Enable the Screen tip check box.
Type a value in the Gravity radius box.
