HTML files are plain-text (also known as ASCII) files that can be created using any text editor, including SimpleText and TextEdit. HTML files are intended for display on a web browser.
You can import HTML files to edit text and add web objects, bookmarks, and hyperlinks. For more information about preparing files and objects for web publishing and uploading to the web, see Exporting to HTML.
3 . |
Choose HTM - HyperText Markup Language (*.htm) from the list box next to the File name box. |
6 . |
In the Use default text colors area, enable one of the following options: |
Yes — uses the default color for text and for visited, unvisited, and active links, ignoring the colors specified in the HTML file |
No — uses the colors specified in the HTML file |
Importing an HTML file
The HTML import filter extracts editable information from a web document and brings objects into Corel DESIGNER in a manner similar to the original layout. |
