You can insert a linked or embedded object. A linked object remains connected to its source file; whereas an embedded object is not linked to its source file but is integrated into the new file. You can insert an embedded object or create an embedded object. You can also insert a linked or embedded object by copying it from the source application and pasting it to the destination application.
The file from which you copy the object in the source application must be saved before you insert the object in Corel DESIGNER.
| 1 . |
Click Object Insert new object. |
You can also create an embedded object by enabling the Create new option in the Insert new object dialog box, and choosing the application in which you want to create the object from the Object type list box.
You can also insert an embedded object by selecting an object in the source application, and dragging it to the application window of Corel DESIGNER.
