You can choose between the following types of installations:
• | Typical installation — automatically installs the main programs and utilities of the suite to a default location in the Program Files folder. If later you need a component that is not installed, you can modify your installation. |
• | Custom installation — lets you choose additional features, exclude components that you don’t need, and specify where to install the suite. For example, you can install desktop shortcuts or install Ghostscript for better handling of imported EPS and PDF files. |
• | Deployment — available only for multiseat purchases. This option lets you create a server image for installing the software to individual workstations. For more information, see the CorelDRAW Technical Suite X7 Deployment Guide. |
Program features and utilities
To use VSTA with CorelDRAW Technical Suite, you must have your own copy of Microsoft Visual Studio 2012 or later installed.
If you install Microsoft Visual Studio after installing CorelDRAW Technical Suite, you must re-install the VSTA feature by modifying your CorelDRAW Technical Suite installation. For more information, see To modify or repair a CorelDRAW Technical Suite X7 installation.
If you have installed CorelDRAW Graphics Suite or CorelDRAW Technical Suite before, this option does not appear in the installation wizard.
The following table lists additional installation options.
