New! 3D illustration updating
To speed up technical-publication authoring, CorelDRAW Technical Suite X7 with the Lattice3D Studio CAD Corel Edition Add-On offers the Auto detection and update command. It lets you automatically generate updated vector illustrations to replace ones in DES files that were created using the Send to Corel DESIGNER command. The illustration specifications, such as view, positions of the objects, line weights and export settings, are fully recognized and maintained. As a result, the illustrations are recreated using the updated 3D model and inserted in the same place as the original, allowing technical illustrators to start a publication with a preliminary 3D design and update it with the final design instantly.
You can automatically update 3D illustrations.
Enhanced! Insert 3D model
Corel DESIGNER X7 offers you more flexibility when you insert a 3D model in a drawing. You can now embed a 3D model (XVL file), which gives you the option of editing the 3D model within the Corel DESIGNER (DES) file at any time. What’s more, if you share the file with other users, they’ll be able to work directly with the embedded 3D model, eliminating the need to distribute both the DES and external XVL files. And just as in previous versions, you can link a 3D model, which automatically updates it in a DES file whenever the XVL file is modified in Lattice3D Studio CAD Corel Edition. For more information, see Inserting and adjusting 3D models.
You can embed or link 3D models in drawings.
New! Fill selector
Accessible from the property bar, the Property manager docker, and the Edit fill dialog box, the new Fill selector makes searching, previewing, and selecting fills quick and easy. It also provides access to both locally stored fills and those available in the Content Exchange.
The new Fill selector makes searching, previewing, and selecting fills quick and easy.
New! Fill sharing
You can share your custom pattern fills in the new Content Exchange.
New! Content Exchange
The new Content Exchange is an online repository that integrates with Corel CONNECT and the suite’s applications, making it quick and effortless to access and share vector fills, bitmap fills, and fountain fills with a community of other users. For more information, see Accessing content.
You can browse the content available on the Content Exchange.
New! Content Exchange — Favorites
New! Content Exchange —Vote up and Vote down
New! Syncing trays with Microsoft OneDrive
You can now sync Corel CONNECT trays with Microsoft OneDrive, which provides cloud-based access to your tray contents on other computers or mobile devices. For more information, see Syncing trays with OneDrive.
You can access to your design assets on other computers or mobile devices.
