| • | To add content to a tray |
| • | To add content to a folder |
| • | To remove content from a tray |
| • | To create a tray |
| • | To change the folder to which trays are saved |
| • | To work with trays |
A tray is useful for gathering content from various folders. While the files are referenced in the tray, they actually remain in their original location. You can add and remove content from the tray. The tray is shared between CorelDRAW, Corel DESIGNER, Corel PHOTO-PAINT, and Corel CONNECT. You can also open files from the tray to preview them more easily.
You can create trays so that you can organize your content. Trays are saved to the My Documents\Corel\Corel Content\Trays folder, but you can change the default folder to which trays are saved.
| • | Select one or more thumbnails in the viewing pane, and drag them to the tray. |
| If you want to open a file from the tray, double-click its thumbnail. |
You can also drag content from a folder on your computer to the tray.
| • | Select one or more thumbnails in the viewing area, and drag them to a folder in the Favorite folders or Folders pane, or any other folder on your computer. |
You can drag content from the tray to a folder.
| • | Select one or more thumbnails in the tray, and click the Remove from tray button |
| To create a tray |
| • | Click the Add new tray button |
| By default, trays are saved to the My Documents\Corel\Corel Content\Trays folder. |
You can email trays that contain only online content.
| 1 . | In the standalone utility, click the arrow on the Help and options button, and click Options. |
| 2 . | Type a path in the Default tray location box. |
To browse to a folder, click the Browse button next to the Default tray location box.
Right-click the tray tab, click Rename, and type a new name.
Click the All trays arrow, and click a tray.
Click the All trays arrow, click Open tray file, and navigate to the tray file.
Holding down Ctrl, press Tab.
You can also close and delete a selected tray from the All trays menu.
