When using a curve tool, you can turn on parallel drawing to create a line parallel to the line that you are drawing. You can specify whether the parallel line appears to the left or to the right of the original line. In addition, you can set the distance between the original line and the parallel line by specifying a value or dragging in the document.
Corel DESIGNER lets you create single or multiple parallel lines and preview them as you draw. You can also add parallel lines to an existing line.
From left to right: Parallel drawing with the 2-point line tool, 3-point curve tool, and Pen tool
1 . |
Click the Curve tools button, and click a curve tool. |
3 . |
On the Parallel Drawing toolbar, click the Parallel lines button . |
You can also display the Parallel Drawing toolbar by clicking View Toolbars Parallel Drawing.
3 . |
On the Parallel Drawing toolbar, specify the settings you want. |
