• | To customize the font list |
• | To preview a font |
• | To resize the Font list area |
You can customize the font list, from within the Font list box, to make it easier to find fonts. For example, you can change the size of the font names displayed in the Font list box. You can display fonts grouped by family or as a flat list. If you have non-Latin fonts installed, you can show their names in Latin or in their native language. In addition, you can show recently used fonts at the top of the font list, or hide them, and you can specify the number of recently used fonts to display.
Corel DESIGNER lets you preview fonts in the Preview area at the bottom of the Font list box or in the drawing window. You can also preview a font in all available styles, such as bold and italic.
You can resize the Font list area by adjusting its height and width or by hiding the preview area.
1 . | Click the Text tool in the toolbox, and open the Font list box on the property bar. |
2 . | To change the size of the font names, move the Zoom slider. |
3 . | Click the Font Options button , and perform a task from the following table. |
Click Group by family to enable or disable the command.
Click Show Latin names to enable or disable the command.
Click Use font to display the font name to disable the command.
Click Show recently used fonts to enable or disable the command.
Click Font List Options, and on the Fonts page of the Options dialog box, type a value in the Number of recently used fonts displayed box.
To preview a font |
1 . | Click the Text tool in the toolbox. |
If you want to preview a font in the drawing window, select the text you want. |
2 . | On the property bar, click the Font list box. |
The font name appears in the given font. |
To preview the selected text with a specific font applied, point to the font name in the Font list box. |
If a font has other styles, such as bold or italic, you can preview them by pointing to the flyout arrow next to the font name.
2 . | Do any of the following: |
• | To hide the preview area, click the Hide preview button . |
• | To adjust the width of the Font list area, point to the vertical grab area (right edge) and drag when the double-sided arrow appears. |
• | To adjust the height, point to the horizontal grab area (above the Zoom slider), and drag when the double-sided arrow appears. |
