• | To specify color settings for printing |
• | To print using color proofing settings |
• | To specify a rendering intent for printing |
Corel DESIGNER allows you to manage colors when printing to ensure accurate color reproduction. You can print the document with the document colors settings applied or you can choose alternate color settings only for printing. You can also print a document using the color proofing settings that you previously specified in the Color proof settings docker. For more information, see Using color management.
In addition, you can choose a rendering intent to effectively interpret the out-of-gamut colors when printing. The rendering intent that you choose depends on the graphic content of the document. For more information, see Understanding color management.
For more information about color management, see Using color management.
You can determine if a printer is a GDI printer by clicking File Print and choosing a printer from the Printer list box. If the PostScript tab does not appear at the top of the dialog box, the selected printer is a GDI printer.
The following table describes different ways of managing color when printing to a GDI printer.
Click the Color tab, and choose the appropriate color mode from the Output colors as list box.
Click the Color tab, and choose the document color profile from the Document profile area of the Correct colors using color profile list box.
Choose the printer color profile from the Correct colors using color profile list box.
Click the Color tab, and choose Native from the Output colors as list box.
Click the Color tab, and choose a color mode from the Output colors as list box.
Click the Color tab, and choose the color profile from the Output color as list box and from the Correct colors using color profile list box.
1 . | Click File Print. |
2 . | Click the Color tab. |
3 . | Enable the Use document color settings option. |
If you selected a PostScript printer, you can choose one of the following options from the Color conversion performed by list box: |
• | Corel DESIGNER — lets the application perform the color conversion |
• | (selected printer) — lets the selected printer perform the color conversion (This option is only available for PostScript printers.) |
4 . | Choose a color model from the Output colors as list box. |
This allows you to merge all document colors into a specific color model when printing. |
Enable the Convert spot colors to check box.
If you selected Native from the Output colors as list box, you need to select a color mode from the list box.
Choose a color profile from the Correct colors using color profiles list box.
Enable the Preserve (color model) numbers check box.
3 . | Enable the Use color proof settings option to apply the color settings that are defined in the Color proof settings docker. |
If you want to correct the proof colors, you can choose a color profile from the Correct colors using color profile list box. |
4 . | Click Print. |
3 . | From the Rendering intent list box, choose one of the following options: |
• | Relative colorimetric — for producing proofs on printers, without preserving the white point |
• | Absolute colorimetric — for preserving the white point and proofing |
• | Perceptual — for a variety of images, especially bitmaps and photographs |
• | Saturation — for vector graphics and for preserving highly saturated colors (lines, text, and solid-colored objects, such as charts) |
