| • | To rotate an object |
You can rotate an object in a drawing by specifying an angle of rotation. You can also specify a point on the drawing around which to rotate, or rotate around a point on the selected object.
| 1 . | Select an object. |
| 2 . | Click the Shape tools button in the toolbox, and click the Free transform tool |
| 3 . | Click the Free rotation button |
| If you want to change the reference point to use when rotating the object, locate the Object origin icon |
| 4 . | Type a value in the Angle of rotation box on the property bar. |
| To specify a point on the drawing to rotate around, type coordinates in the Center of rotation boxes on the property bar. |
Click the Relative to object button
Rotate an object using the Transformations docker
In the Transformations docker, click the Rotation angle button
In the Transformations docker, click the Specify point button
In the Center area of the Transformations docker, enable the Relative center check box, and click the point on the origin locator
In the Transformations docker, enable the Rotate orientation option
In the Transformations docker, enable the Retain orientation option
In the Transformations docker, type a number in the Copies box.
You can also rotate a selected object by dragging a rotation handle
clockwise or counterclockwise.
You can also rotate an object by typing a value in the Angle of rotation box on the Transform toolbar. To display the Transform toolbar, click View
Toolbars
Transform.
