By default, drawings are saved to the Corel DESIGNER file format (DES). You can save a drawing to other vector file formats as well. If you want to use a drawing in another application, you must save it to a file format that is supported by that application. For information about saving files to other formats, see Exporting files.
When saving a drawing, you can embed the used fonts to facilitate file sharing. By default, Corel DESIGNER embeds all used fonts, with the exception of Asian fonts and fonts that do not have embedding permissions. For more information, see Embedding fonts.
When you save a drawing, Corel DESIGNER lets you add reference information so that you can easily find and organize drawings later on. You can attach tags (also known as properties) such as title, subject, and rating.
You can also save selected objects in a drawing. For large drawings, saving only the selected objects reduces the file size, which can decrease the time it takes to load the drawing.
When saving a file, you can use advanced options to control how bitmaps, textures, and vector effects, such as blends and extrusions, are saved with the drawing.
You can also save a drawing as a template, which lets you create other drawings with the same properties. For information about saving a drawing as a template, see Working with templates.
If you are using an expired trial version of Corel DESIGNER, you will not be able to save drawings.
Saving a drawing to a previous version of Corel DESIGNER may result in loss of certain effects that were not available in the previous version of the application.
When you save a drawing to the latest version of the CorelDRAW file format, the option Make compatible with version 17.0 is enabled by default. This option ensures that the file can be opened in CorelDRAW X7.3 and earlier X7 versions. If the file contains new features such as drop shadows with Gaussian blur feathering, this option results in a bigger file size.
You can also save a drawing by clicking File Save.
You can also save a drawing by clicking the Save button on the Standard toolbar.
Save presentation exchange (CMX) — saves a drawing as a Corel Presentations Exchange (CMX) file so that you can open and edit it in other Corel applications, such as WordPerfect |
Use bitmap compression — reduces the file size by compressing bitmap effects, such as bitmap extrusions, transparencies, and drop shadows |
Choosing to save textures, blends, and extrusions with the file increases the file size but lets you open and save a drawing more quickly. Conversely, choosing to rebuild textures, blends, and extrusions when a saved drawing is opened decreases the file size but increases the time required for saving or opening a drawing.
Keep appearance — preserves the appearance of text, fills, outlines and transparencies when the file is opened in a previous version of Corel DESIGNER. However, this option may limit editing. |
Keep editable — preserves the file editable. However, this option may change the appearance of text, outlines, fills, and transparencies when the file is opened in a previous version of Corel DESIGNER. |
Click Tool Options. In the Workspace list of categories, click Save, and enable one of the following options:
Click Tool Options. In the Workspace list of categories, click Save, and disable the Ask when saving check box.
