| • | To select a text object |
| • | To select text for editing |
Corel DESIGNER lets you select text to edit specific characters or modify it as an object. For example, you can select specific characters to change the font or select a text object, such as a text frame, so you can move, resize, or rotate it.
Using the Pick tool
Using the Pick tool
You can use the Pick tool
to select multiple text objects. Hold down Shift, and click each text object.
Using the Text tool
Using the Text tool
