Setting preferences for exporting images to HTML
You can set preferences for exporting images that are destined to be viewed on the web. For example, you can determine layout options, such as size and position of the image white space.
You can also publish your document as a single image, from which the application creates an image map. An image map is a hypergraphic whose hotspots link to different URLs — including pages, locations, and images — when you view the HTML document with a browser. Note that large image maps might cause slow downloads for those with a slow Internet connection.
To set preferences for exporting images to HTML Back to Top
Specify the number of pixels text can be automatically nudged to avoid introducing rows or columns that are only a few pixels in size
Type a value in the Position tolerance box.
Type a value in the Image white space box.
Type a value in the Position white space box.
In the Image map type area, enable the Server check box, and choose a format.
