| • | To specify the size of an object |
| • | To size an object interactively |
| • | To scale an object |
Corel DESIGNER lets you size and scale objects. In both cases, you can change the dimensions of an object proportionally by preserving its aspect ratio. You can size an object by specifying values or changing the object interactively. Scaling changes an object’s dimensions by a specified percentage.
You can also specify a rectangular area for selected objects to scale into.
| 1 . | Select an object. |
| 2 . | Click View |
| 3 . | Type values in the Object size boxes on the Transform toolbar. |
Click the Relative to object button
Size an object by using the Transformations docker
Clicking Object
In the Transformations docker, enable the Proportional check box.
In the Transformations docker, click the point on the origin locator
In the Transformations docker, type a number in the Copies box.
Hold down Shift, and drag one of the selection handles.
Hold down Ctrl, and drag one of the selection handles.
Hold down Alt, and drag one of the selection handles.
You can set a precise size for the object by clicking the Geometric properties button
on the property bar and typing values in the Property manager docker.
| 2 . | Click the Shape tools button in the toolbox, and click the Free transform tool |
| 3 . | Click the Free scale button |
| If you want to change the reference point to use when scaling the object, locate the Object origin icon |
| 4 . | On the property bar, type values in the Scale factor boxes to specify a percentage by which to scale the object horizontally or vertically. |
| If you want to maintain the aspect ratio, click the Lock ratio button |
Scale an object by using the Transformations docker
Click Object
In the Transformations docker, enable the Fit to box option.
You can also scale an object by dragging a selection handle.
You can also scale an object by typing values in the Scale factor boxes on the Transform toolbar. To display the Transform toolbar, click View
Toolbars
Transform.
