• | To undo, redo, and repeat actions |
• | To specify the Undo settings |
Customizing the Undo settings lets you increase or decrease the number of actions that you can undo or redo.
Click Edit Undo manager.
Click Edit Redo.
Click Window Undo manager. In the Undo manager docker, click the action that precedes all the actions that you want to undo, or click the last undone action that you want to redo.
Click File Revert.
Click Edit Repeat.
When you undo a series of actions in the Undo manager docker, all actions listed below the action that you click are undone.
When you redo a series of actions in the Undo manager docker, the action that you click and all preceding undone actions are redone.
You can repeat an action on another object or group of objects by selecting the object or objects and clicking Edit Repeat.
You can also undo or redo a series of actions by clicking the arrow button next to the Undo button or Redo button on the Standard toolbar and choosing an action from the list.
1 . | Click Tools Options. |
2 . | In the Workspace list of categories, click General. |
3 . | In the Undo levels area, type a value in one or both of the following boxes: |
• | Regular — specifies the number of actions that can be reversed when you use the Undo command with vector objects |
• | Bitmap effects — specifies the number of actions that can be reversed when you work with bitmap effects |
