Using checking styles
A checking style is a preset writing style rule applied to a drawing. Using a checking style lets you check a drawing that has a specific type of writing. For example, you can choose an advertising checking style to check advertising copy or marketing materials.
You can create, delete, edit, and restore a checking style.
You can specify a maximum number of items when Grammatik checks the grammar of a drawing. For example, you can specify the maximum number of consecutive nouns that Grammatik allows.
Choosing a formality level lets Grammatik check a drawing for strict or relaxed use of language and diction. Each checking style has a default level of formality assigned to it. Each formality level focuses on a different style of writing. You can choose from three formality levels: informal, standard, and formal.
To select a checking style Back to Top
A checking style remains in effect until you disable the checking style or choose another one.
To create a checking style Back to Top
To delete a checking style Back to Top
You can delete custom checking styles, but you cannot delete preset checking styles.
To edit a checking style Back to Top
When you save an edited checking style, an asterisk (*) is added to the style name.
To restore an edited checking style Back to Top
Custom checking styles saved with new names cannot be returned to default settings.
To specify the maximum number of specific items Back to Top
Set the Spell numbers below or equal to value to zero if you do not want numerals to be flagged as errors.
To change a formality level Back to Top
