Standard feature
You can configure pen tablet options quickly and easily from the Pen Settings page in the Options dialog box.
When you use a pressure-sensitive stylus or pen tablet with Corel DESIGNER, the amount of pressure that you apply controls the width of your strokes. Each person uses a different strength or pressure level in a stroke, and you can set the application to match your stroke strength by specifying pen settings. Proper pen settings are particularly useful if you have a light touch. If a light stroke leaves no trace, adjusting pen settings can increase sensitivity for specific tools. Abrupt changes in the width your brushstrokes shows that you need to adjust your pen settings.
The following tools in Corel DESIGNER let you use the pressure of your device: Pressure, Roughen, Smudge, Eraser as well as the liquid tools.
With Premium membership, you can also take full advantage of the pressure and tilt of your RTS-compatible pen tablet or device to control your brushstrokes. For more information, see Support for Real-Time Stylus (RTS) pen tablets and devices.
2 . |
In the Global list of categories, click Pen Settings. |
