Using rule classes
Rule classes contain groups of grammar and style rules. Grammatik uses rule classes to detect common writing errors.
You can enable or disable rules at any time during a Grammatik session. When you disable a rule, Grammatik ignores all the errors associated with that rule during the current proofreading session. You can also choose which rule classes to apply during a Grammatik session or save a new set of rules as a checking style.
To enable a rule Back to Top
The Turn on rules command is available only when you have disabled a rule during proofreading. Otherwise, it is grayed.
To disable a rule Back to Top
To add rule classes Back to Top
To save a set of rules as a new checking style Back to Top
The Save rules command is available only when a rule has been turned off.
