When you start a document from a template by using the File New from template command, Corel DESIGNER formats the page according to the page layout settings in the template and then loads all objects and template’s styles into the new document. With this method, you can search and browse for templates.
If you want to use only the styles from a template, you can create a blank document by using the File Open command.
You can also import styles from a template into a document at any time.
1 . |
Click File New from template. |
For information about searching for templates, see To search for templates.
You can also start a document from a template by clicking File Open, locating the template, double-clicking it, and enabling the New from template check box in the Open dialog box. If you want to use only the template’s styles, disable the With contents check box.
1 . |
Click Window Object styles. |
2 . |
In the Object styles docker, open the Import, export, or save defaults flyout, and then click the Import style sheet button . |
Only the template styles are imported. Page layout settings and objects saved with the template are ignored. The attributes of existing objects are maintained.
