A word list is a list of words or phrases scanned when you proof text by using the writing tools. Writing tools scan two types of word lists: user word lists and main word lists. Each language comes with a default user word list. You can customize user word lists by adding, deleting, or replacing words. Main word lists are lists of specialized words used by the spelling checker for a particular language, field or company.
You can choose a user word list to help proof a text. You can have up to 10 user word lists active simultaneously. For example, if you want the spelling checker to scan both the US English and the Canadian English main word lists, choose both lists. If you work in the medical profession, you can select a third-party medical word list that runs with the writing tools. Each language supported by the spelling checker has a default main word list. The active user word lists are scanned first; if the word or phrase is not found there, the active main word lists are scanned. You can add, disable, or remove word lists.
You can add a word to a user word list so that the word is not flagged as an error. You can also add replacement words to a user word list, which lets you choose a replacement when the spelling checker or Grammatik stops on a word.
You can edit or delete words in a user word list at any time.
1 . |
Click Text Writing tools, and click one of the following: |
2 . |
Click Options User word lists. |
![*](images/note.gif)
The default user word list for the language is always enabled.
1 . |
2 . |
3 . |
Click in the User word lists list where you want to position the new user word list. |
5 . |
In the Add user word list dialog box, choose the new user word list. |
The filename extension for a user word list is .uwl.
When you check a drawing, the user word lists are scanned in the order of their appearance in the User word lists dialog box.
1 . |
2 . |
1 . |
Click Text Writing tools Spell check. |
2 . |
You cannot remove the default language word list.
1 . |
2 . |
3 . |
In the User word lists dialog box, choose a user word list. |
In the spelling checker, replacement words appear in the Replacements box.
![*](images/tip.gif)
Click Add from the Spell checker or Grammatik pages to add the word to the current user word list.
You can also add short phrases to a user word list.
1 . |
2 . |
3 . |
1 . |
2 . |
If the word list you want to edit does not appear in the User word lists dialog box, click Add list to open the list.
1 . |
2 . |
