| • | To add a block shadow |
| • | To edit a block shadow |
| • | To set printing and exporting options for block shadows |
| • | To remove a block shadow |
The Block Shadow tool in Corel DESIGNER lets you add solid shadows to objects and text. Unlike drop shadows and extrusions, block shadows consist of simple lines, which makes them ideal for screen printing and sign making.
The Block Shadow tool is located on the Interactive tool flyout.
You can remove block shadows from objects at any time.
| 1 . | In the toolbox, click the Block Shadow tool |
| 2 . | Click the object, and drag in the direction you want until the block shadow is the size you want. |
| 1 . | Using the Block Shadow tool |
| 2 . | Perform any of the tasks from the following table. |
Type a value in the Depth box.
Type a value in the Direction box.
Choose a color from the Block shadow color picker on the property bar.
Click the Remove holes button
Top: A block shadow with holes. Bottom: The same block shadow with the holes removed. |
On the property bar, click the Generate from object outline button
Click the Overprint block shadow button
Click the Simplify button
| 1 . | Using the Block Shadow tool, click the block shadow. |
| 2 . | Click the Clear block shadow button |
