You can use textures to create transparency effects. You can use existing textures, such as water, minerals, and clouds, or you can edit a texture to create your own texture transparency.
A texture transparency is applied to the object filled with light green.
When you edit a texture, you can modify its parameters, such as softness, density, brightness, and colors. Parameters vary for each texture. You can also apply other transformations, such as mirror, resize, or offset the texture tiles. After you have edited a texture, you can save it for future use.
2 . |
Click Edit Property manager. |
3 . |
In the Transparency area of the Property manager docker, click the flyout arrow on the Two-color pattern transparency button , and click the Texture transparency button to display texture transparency options. |
To apply the transparency only to the fill or the outline of the object, click the Fill button
or the Outline button
To modify the texture, click the Edit transparency button
, and specify the settings you want.
You can also click the Transparency tool
in the toolbox and use the controls on the property bar.
