| • | Charcoal |
| • | Conte crayon |
| • | Crayon |
| • | Cubist |
| • | Dabble |
| • | Impressionist |
| • | Palette knife |
| • | Pastels |
| • | Pen and ink |
| • | Pointillist |
| • | Scraperboard |
| • | Sketch pad |
| • | Watercolor |
| • | Water marker |
| • | Wave paper |
| Charcoal |
The Charcoal effect makes an image look like a black-and-white charcoal drawing.
| Conte crayon |
The Conte crayon effect simulates textures produced with a conté crayon. You can select multiple crayon colors and set the crayon pressure and the granularity of the texture.
| Crayon |
The Crayon effect makes an image look like a wax crayon drawing. You can specify the crayon pressure and create dark outlines around elements in the image.
| Cubist |
The Cubist effect groups similarly colored pixels into squares to produce an image that resembles a cubist painting. You can specify the square size, the amount of light, and the paper color.
| Dabble |
The Dabble effect (Effects
Art strokes
Dabble) makes image pixels look like dabs of paint. You can choose from a variety of brushstrokes and specify the brushstroke size.
| Impressionist |
The Impressionist effect makes an image look like an impressionist painting. You can customize the dabs of color or the brushstrokes and specify the amount of light in the image.
| Palette knife |
The Palette knife effect creates the impression that an image was created by spreading paint on a canvas with a palette knife. You can specify the amount of smudging and the size and direction of the brushstrokes.
| Pastels |
The Pastels effect makes an image look like a pastel drawing. You can specify the size and color variation of the brushstrokes.
| Pen and ink |
The Pen and ink effect makes an image look like a pen-and-ink drawing created with a cross-hatching or stipple technique.
| Pointillist |
The Pointillist effect analyzes the main colors of an image and converts them to small dots. You can specify the size of the dots and the amount of light in the image.
| Scraperboard |
The Scraperboard effect scrapes away a black surface to reveal white or another color, making an image look like a sketchy drawing. You can specify the density of the paint and the brushstroke size.
| Sketch pad |
The Sketch pad effect makes an image look like a pencil sketch.
| Watercolor |
The Watercolor effect makes an image look like a watercolor painting. You can specify the brush size, granulation level, and image brightness. You can also specify the intensity of the colors and determine the degree to which the colors blend.
| Water marker |
The Water marker effect makes an image look like an abstract sketch created with color markers. You can change the brushstrokes by selecting different modes. You can also specify the size and color variation of the brushstrokes.
| Wave paper |
The Wave paper effect makes an image look like a painting created on textured wave paper. You can create a black-and-white painting, or you can preserve the original color of the image.
