| • | To bring a RAW camera file into Corel DESIGNER |
When you open single or multiple RAW camera files in Corel DESIGNER, they are first displayed in the Camera RAW Lab. You can use the controls in the Camera RAW Lab to adjust the color and tone of the RAW camera images.If you are satisfied with the adjustments of a file, you can apply the same adjustments to the remaining files.
Note that RAW camera files cannot be saved to a RAW camera file format in Corel DESIGNER. Any changes made to the RAW camera files in the Camera RAW Lab are lost unless you save the files to a supported file format.
The Camera RAW Lab includes controls that are organized in a logical order for color correction and other adjustments of RAW camera images. It is recommended that you start from the top of the Color page and work your way down. Once you finish correcting the color and tone of your image, you can sharpen it and remove noise by using the controls on the Detail page. For information about the settings on the Color page, see Adjusting the color and tone of RAW camera files. For information about the settings on the Detail page, see Sharpening and reducing noise in RAW camera files.
4. Color page
5. Detail page
6. Properties page
7. Undo and Redo buttons
8. Reset to original button
9. Create snapshot
| 1 . | Click File |
| 2 . | Select the RAW camera file or files that you want to import, and click Import. |
| 3 . | In the Camera RAW Lab, adjust the color and tone of the RAW camera image. If necessary, you can also sharpen the image and reduce the amount of noise. |
| If you selected multiple RAW camera files and want to apply the same adjustments to all of them, enable the Apply to all remaining files check box. |
You can rotate the image by clicking the Rotate left button or Rotate right button
