• | Bit planes |
• | Halftone |
• | Psychedelic |
• | Solarize |
Bit planes |
The Bit planes effect reduces an image to basic RGB color components and displays tonal changes using solid colors. You can adjust the tonal values of each color component individually or as a group.
Halftone |
The Halftone effect gives an image the appearance of a color halftone. A color halftone is an image that has been converted from a continuous tone image to a series of dots of various sizes that represent different tones. You can specify the size of the biggest dot and vary the color pattern. Move the Max dot radius slider to set the maximum radius of a halftone dot. The Cyan, Magenta, Yellow, and Black sliders specify the angles of the cyan, magenta, yellow, and black color screens.
Psychedelic |
The Psychedelic effect changes the colors in an image to bright, electric colors, such as orange, hot pink, cyan, and lime green. The Psychedelic effect is also a preset lens type.
Solarize |
The Solarize effect transforms colors in an image by reversing image tones. The Solarize effect is also a preset lens type.
