You can copy object properties such as outline, fill, and text properties from one object to another. You can copy object transformations such as sizing, rotating, and positioning as well as effects applied to an object.
1 . |
Click the Eyedropper tools button, and click the Attributes eyedropper tool . |
2 . |
Click Properties on the property bar, and enable any of the following check boxes: |
The Attributes eyedropper tool automatically switches to the Apply object attributes mode. |
![*](images/note.svg)
Any Transformations and Effects options on the property bar that are enabled are also applied when you copy properties.
![*](images/tip.svg)
You can also copy fill or outline properties, or both, by right-clicking an object with the Pick tool
, dragging over another object, and choosing Copy fill here, Copy outline here, or Copy all properties.
You can also copy object properties to a selected object by clicking Edit
Copy properties from and clicking the object whose properties you want to copy.
1 . |
2 . |
Click Transformations on the property bar, and enable any of the following check boxes: |
Any Properties and Effects options on the property bar that are enabled are also applied when you copy properties.
1 . |
2 . |
Click Effects on the property bar, and enable any of the following check boxes: |
Any Properties and Transformations options on the property bar that are enabled are also applied when you copy properties.
