Corel customization features let you modify the menu bar and the menus it contains. You can change the order of menus and menu commands; add, remove, and rename menus and menu commands. You can search for a menu command if you do not remember the menu in which it belongs. You can also reset menus to the default setting.
The customization options apply to the menu bar menus as well as to shortcut menus that you access by right-clicking.
Help topics are based on the application’s default settings. When you customize menus and menu commands, the Help topics associated with them do not reflect your changes.
| 1 . |
Click Tools Customization. |
| 2 . |
In the Customization list of categories, click Commands. |
| 1 . |
| 2 . |
An ampersand (&) before a letter in the Caption box indicates a shortcut, also known as an accelerator key. Menus are displayed by pressing Alt + the letter. Commands are invoked by pressing the letter that is underlined when the menu is displayed.
You can reset the name to the default by clicking Restore defaults.
| 1 . |
| 2 . |
| 1 . |
| 2 . |
| 1 . |
| 2 . |
| 4 . |
In the Find text dialog box, type the menu command in the Find what box. |
| 1 . |
| 2 . |
In the Customization list of categories, click Command bars. |
| 3 . |
Choose Menu bar from the list. |
