Corel DESIGNER and CorelDRAW give you direct access to your organization’s Microsoft SharePoint document management system (DMS).
The Document Management feature is available only if your organization has licensed CorelSure Maintenance.
To use your organization’s DMS with Corel DESIGNER and CorelDRAW, you must log in to SharePoint by using your SharePoint credentials, not your Corel.com account credentials.
Saving documents to a document library
You can share Corel DESIGNER (DES) and CorelDRAW (CDR) documents with others by saving them to your organization’s document library. After you save a document to the document library, others can view the document, or check it out, provided they have the permission to do so.
Using the working folder
By default, Corel DESIGNER places a folder called "Working Files" in My Documents, so the location of the default working folder is as follows:
Users\<Your name>\Documents\Working Files
The file you check out is copied to the working folder, and you can modify the file in Corel DESIGNER from that location. When you are ready to check in the changes, the file is copied from the working folder back into the SharePoint document library. For information about checking out files, see "Checking documents in and out of a document library" on page 11.
You can change the working folder, although you should never need to do so.
You must check in all checked-out files before changing the working folder. If you change the working folder while files are checked out; you will not be able check them in from within Corel DESIGNER.
| 1 . |
Click File Document Management Save. |
| 2 . |
In the Save dialog box, type the document library URL in the Look in text box, and then press Enter. The URL must have the proper format: http://[ServerName]/[Site]/[Name]. |
You can save only Corel DESIGNER (DES) and CorelDRAW (CDR) documents.
To save the document to a local folder, click File
Save As.
| 3 . |
In the Global list of categories, click File Locations. |
| 4 . |
Click Documents, and click the Browse button , located to the right of the file path. |
| 5 . |
In the Browse for Folder dialog box, navigate to the folder you want. |
Click Documents, and click Reset.
Click View Toolbars Document Management. |
