HTML files are plain-text (also known as ASCII) files that can be created using any text editor, including SimpleText and TextEdit. HTML files are intended for display on a web browser.
You can import HTML files to edit text and add web objects, bookmarks, and hyperlinks.
| 3 . |
Choose HTM - HyperText Markup Language (*.htm) from the list box next to the File name box. |
| 6 . |
In the Use default text colors area, enable one of the following options: |
Yes — uses the default color for text and for visited, unvisited, and active links, ignoring the colors specified in the HTML file |
No — uses the colors specified in the HTML file |
Importing an HTML file
The HTML import filter extracts editable information from a web document and brings objects into Corel DESIGNER in a manner similar to the original layout. |
