| • | To add a drop cap |
You can add a drop cap (left) or a hanging indent drop cap (right).
| To add a drop cap |
| 1 . | Using the Text tool |
| If the Property manager docker is not open, click Window |
| 2 . | In the Property manager docker, click the Paragraph button |
| 3 . | In the Paragraph area of the Property manager docker, click the arrow button |
| 4 . | Enable the Drop caps check box. |
| 5 . | Click the Drop caps settings button |
| 6 . | In the Drop cap dialog box, perform a task from the following table. |
In the Appearance area, type a value in the Number of lines dropped box.
In the Appearance area, type a value in the Space after drop cap box.
Enable the Preview check box.
Enable the Use hanging indent style for drop cap check box.
In the Paragraph area of the Property manager docker, disable the Drop caps check box.
