You can choose between the following types of installations:
| • | Typical installation — automatically installs the main programs and utilities of the suite to a default location in the Program Files folder. If later you need a component that is not installed, you can modify your installation. |
| • | Custom installation — lets you choose additional features, exclude components that you don’t need, and specify where to install the suite. |
| • | Deployment — available only for multiseat purchases. This option lets you create a server image for installing the software to individual workstations. For more information, see the CorelDRAW Technical Suite 2018 Deployment Guide. |
Program features and utilities
To use VSTA with CorelDRAW Technical Suite, you must have your own copy of Microsoft Visual Studio 2017 installed.
If you install Microsoft Visual Studio after installing CorelDRAW Technical Suite, you must re-install the VSTA feature by modifying your CorelDRAW Technical Suite installation. For more information, see To modify or repair a CorelDRAW Technical Suite installation.
If you have installed CorelDRAW Graphics Suite or CorelDRAW Technical Suite before, this option does not appear in the installation wizard.
