You can lay out a print job by specifying the size, position, and scale. Tiling a print job prints portions of each page on separate sheets of paper that you can assemble into one sheet. You would, for example, tile a print job that is larger than your printer paper.
| 3 . |
In the Image position and size area, enable one of the following options: |
Fit to page — sizes and positions the print job to fit to a printed page |
Enabling the Reposition images to option lets you specify size, position, and scale in the corresponding boxes.
You can also choose an imposition layout, such as 2 x 2 (4-up) or 2 x 3 (6-up), from the Imposition layout list box. For more information, see Working with imposition layouts.
| 3 . |
In the Image position and size area, enable the Print tiled pages check box. |
Tile overlap — lets you specify the amount by which to overlap tiles |
% of page width — lets you specify the percentage of the page width the tiles will occupy |
You can include tiling alignment marks by enabling the Tiling marks check box.
