Corel DESIGNER also supports the following file formats:
| • | ANSI Text (TXT) — ANSI Text (TXT) is a vector format that stores ANSI characters. This format is able to store text information but not formatting information, such as the font type or size. When a TXT file is imported to or exported from Corel DESIGNER, only the text is transferred. If the file has graphic elements, they are not imported or exported. |
| • | Corel ArtShow 5 (CPX) — The CPX file format is a native file format of Corel ArtShow 5. It can contain both vectors and bitmaps. |
| • | Corel Presentations (SHW) — The SHW file format is a native format of Corel Presentations. |
| • | Corel R.A.V.E. (CLK) — The CLK file format is an animation file format that is native to Corel R.A.V.E. |
| • | CorelDRAW Compressed (CDX) — The CDX file format is a compressed CorelDRAW file. |
| • | Corel DESIGNER or CorelDRAW Template (CDT) — The CDT file format is for a Corel DESIGNER or CorelDRAW template file. |
| • | EXE — The EXE format is a Windows 3.x/NT bitmap resource and can store an ICO file as a Windows 3.x/NT icon resource. |
| • | FPX — The FlashPix file format stores images at different resolutions in a single file. This file format is not supported by the 64-bit version of the suite. |
| • | Frame Vector Metafile (FMV) — The FMV file format is used for a Frame Vector Metafile. |
| • | GEM File (GEM) — The GEM file format is used for a GEM file. |
| • | GIMP (XCF) — XCF is the native GIMP format. It supports layers and other GIMP-specific information. |
| • | ICO — The ICO format is a Windows 3.x/NT icon resource. |
| • | Macromedia FreeHand (FH) — the FH format is the native vector file format for Macromedia Freehand. Corel graphics applications support versions 7 and 8 of Macromedia FreeHand. |
| • | MET Metafile (MET) — The MET file format is for a MET Metafile. |
| • | Picture Publisher File (PPF) — The PPF file format is native to Micrografx Picture Publisher 6, 7, 8, 9, and 10. This file format is not supported by the 64-bit version of the suite. |
| • | Microsoft Excel (XLS) — The XLS file format is the native file format of a Microsoft Excel workbook. |
| • | Microsoft PowerPoint (PPT) — The PPT file format is native to Microsoft PowerPoint. |
| • | NAP Metafile (NAP) — The NAP file format is used for a NAP Metafile. |
| • | XPixMap Image (XPM) — The XPM file format is used with an XPixMap Image file. |
