Corel DESIGNER provides an easy way of finding templates.
Searching
You can search by the name, category, or reference information associated with a template. For example, if you type "contemporary" in the text field, the application automatically filters out all files that do not match, and you see only the files that have the word "contemporary" in the template name, category, or designer notes attached to the file.
You can cancel a search at any time.
Filtering search results
You can narrow the search results by using different criteria, such as document type (for example, brochure, flyer, newsletter, or postcard) and industry (for example, hospitality or retail). You can choose to view only templates that you have created or all templates (the templates included with Corel DESIGNER and provided by third-party designers, as well as templates that you have created).
Viewing templates and template information
You can increase the size of thumbnails to recognize a particular template easier and faster, and you can decrease thumbnail size to view more search results at a glance.When you select a template in the viewing area, additional information is displayed about the template’s category, style, pagination, and fold options, as well as any designer notes related to its intended use.
| 1 . |
Click File New from template. |
| 2 . |
In the New from template dialog box, type a word in the Search box, and press Enter. |
| 3 . |
From the View by list box in the Filter pane, choose one of the following categories: |
Type — sorts templates by document type, such as brochure, flyer, or newsletter |
Industry — sorts templates by the industry that the template was designed for (for example, hospitality, retail, or services) |
Custom templates that do not contain any category information are displayed under My templates.
If the Corel DESIGNER shell integration components are not installed (that is, if you have disabled the Windows Shell Extension option under Utilities in the Setup wizard during a custom installation), you can search for templates only by filename, not by name, keywords, or other reference information.
You can also start a search by entering a search term in the Search box and clicking the Start search button
| 1 . |
| 2 . |
In the New from template dialog box, search for templates. |
Drag the Zoom slider to the right or left.
Click a thumbnail in the Templates pane. The template details are displayed in the Template details pane.
If the Template details pane is hidden, click the Show/Hide template details button  to display it.
Click a thumbnail in the Templates pane. The designer notes are displayed in the Designer notes pane.
Click the Print designer notes button  in the lower-left corner of the Designer notes pane.
