| • | To select a node |
| • | To move a node |
| • | To specify a node’s coordinate values |
You can reposition a node by specifying its coordinates.
The Shape tool is the standard tool for moving nodes. You can also set an option to use the Pick and Bézier tools for selecting and moving nodes.
| To select a node |
| 1 . | In the toolbox, click the Shape |
| 2 . | Select a curve object. |
| 3 . | Click a node. |
On the property bar, choose Rectangular from the Selection mode list box, and drag around the nodes that you want to select.
On the property bar, choose Freehand from the Selection mode list box, and drag around the nodes you want to select.
Hold down Ctrl, and click each node.
Holding down Shift, click the first node, and then the last node that you want to select.
Press Tab or Shift + Tab.
Hold down Ctrl, and click a selected node.
Hold down Ctrl, and click each selected node.
| To move a node |
| 1 . | Select an object by using the Shape tool |
| 2 . | Drag the node until you achieve the desired shape. |
| 1 . | Click the Shape tool |
| 2 . | Select a node on a curve object. |
| 3 . | Click Window |
| 4 . | Click the Multi-point curve button |
| 5 . | Type values in the X and Y boxes to specify the exact position of the point along the x and y rulers. |
| 6 . | Click one of the following: |
| • | Create object — adds a new curve object to the drawing window |
| • | Replace object — replaces the selected curve object with a new one |
