| To select a table, row, or column |
| 1 . | Click the Table tool |
| 2 . | Perform one of the following tasks. |
Position the Table tool pointer over the upper-left corner of the table until a diagonal arrow appears
With the Table tool pointer inserted in an empty cell, press Ctrl + A + A.
Position the Table tool pointer over the table border to the left of the row that you want to select. When a horizontal arrow appears
Position the Table tool pointer over the top border of the column that you want to select. When a vertical arrow appears
| To select table cells |
Using the Table tool, click inside the first cell that you want to select, and drag over the adjacent cells that you want to select.
Using the Table tool, click a table. Then, hold down Ctrl, and click each table cell that you want to select.
You can also select a cell by inserting the Table tool pointer in an empty cell and pressing Ctrl + A.
You can also use the Shape tool to select a single cell by clicking it, or to select adjacent cells by dragging over them.
| To move a table row or column |
| 1 . | Select the row or column that you want to move. |
| 2 . | Drag the row or column to another location in the table. |
| To move a table row to another table |
| 1 . | Select the table row that you want to move. |
| 2 . | Click Edit |
| 3 . | Select a row in the other table. |
| 4 . | Click Edit |
| 5 . | Choose one of the following options: |
| • | Replace selected row |
| • | Insert above selected row |
| • | Insert below selected row |
| To move a table column to another table |
| 1 . | Select the table column that you want to move. |
| 2 . | Click Edit |
| 3 . | Select a column in the other table. |
| 4 . | Click Edit |
| • | Replace selected column |
| • | Insert left of the selected column |
| • | Insert right of the selected column |
| To move to the next table cell |
| • | With the Table tool inserted in a cell, press Tab. |
| If you are pressing Tab in a table for the first time, you must choose a tab order option from the Tab order list box. |
You can use the Tab key to move to the next cell only if the Move to the next cell option is enabled in the Tab key options dialog box.
| To change the navigational direction of the Tab key |
| 1 . | Click Tools |
| 2 . | In the Workspace, Toolbox list of categories, click Table tool. |
| 3 . | Enable the Move to the next cell option. |
| 4 . | From the Tab order list box, choose one of the following options: |
| • | Left to right, top to bottom |
| • | Right to left, top to bottom |
You can program the Tab key to insert a tab character in the table text by enabling the Insert a tab character into the text option.
