Guidelines are lines that can be placed anywhere in the drawing window to aid in object placement. In some applications, guidelines are known as guides.
There are three types of guidelines: horizontal, vertical, and angled. By default, the application displays guidelines that you add to the drawing window, but you can hide them at any time. You can also use objects as guides.
You can set guidelines for individual pages or you can set guidelines for the entire document. For more information about local and master guidelines, see Local layers and master layers.
You can add a guideline wherever you need one; however, you can also choose to add preset guidelines. There are two types of preset guidelines: Corel presets and user-defined presets. An example of a Corel preset is one with guidelines that appear at one-inch margins. User-defined presets are guidelines whose location you specify. For example, you can add preset guidelines that display margins at a distance you specify or that define a column layout or grid. You can remove guidelines at any time.
Guidelines use the unit of measure specified for rulers. For information about ruler settings, see To customize ruler settings.
You can also display or hide the guidelines by clicking Tools
Guidelines and clicking the Show or hide guidelines button
You can also access additional guideline options by clicking Tools
Options, and then clicking Guidelines in the Document list of categories.
| 1 . |
Click Tools Guidelines. |
You can also add a guideline by dragging from the horizontal or vertical ruler to the drawing window.
| 1 . |
| 2 . |
Choose Angled from the Guideline type list box. |
You can also add an angled guideline by dragging from the horizontal or vertical ruler in the drawing window, and typing a value in the Angle of rotation box on the property bar.
| 1 . |
In the Object manager docker, click the Guides layer on the page you want. |
If the Object manager docker is not open, click Object Object manager. |
| 1 . |
In the Object manager docker, click Guides (all pages) on the Master page. |
The guidelines that you set on the Guides (all pages) layer of the Master page appear on all pages of the document. These guidelines appear in addition to any guidelines that you set for individual pages.
| 2 . |
In the Document, Guidelines list of categories, click Presets. |
If you enable the User-defined presets option, specify values in the Margins, Columns, or Grid area. |
| 1 . |
You can also remove individual guidelines by dragging them off the document window, or clicking a guideline with the Pick tool and pressing Delete.
To delete a preset guideline, click Tools
Options. In the Document, Guidelines list of categories, click Presets. Disable the check box beside the preset guideline that you want to delete.
