| • | To open a file |
| • | To insert a file into an active document |
| • | To check, purchase, and replace a comp image |
| • | To view a list of all comp images in a document |
If you want to view or edit a file before you incorporate it into your project, you can open it in CorelDRAW, Corel DESIGNER, Corel PHOTO-PAINT, or its associated application.
| To open a file |
| 1 . | Click File |
| 2 . | Search or browse for content. |
| 3 . | Select a thumbnail, and perform an action from the following table. |
Open a file by using the CONNECT docker
Open a file by using the Tray docker
Click the Open button
You can also open a file by right-clicking it and choosing the option that you want.
You can also open multiple selected files.
Note that the Import buttons are not available in the standalone utility.
Click the Import or Import and link button and do one of the following:
You can also insert a file into an active document by dragging the file from the viewing pane or the Tray docker to the active document.
You can also insert multiple selected files.
| 1 . | In your document, click a comp image, and click the Open comp source button on the toolbar that appears below the comp image. |
| 2 . | On the website of the online content provider, check the copyright and usage restrictions for the image, and purchase it if necessary. |
| 3 . | In your document, select the comp image, and click the Replace comp button on the toolbar that appears below the comp image. |
| 4 . | Navigate to the purchased image, and click Import. |
| • | Open a document, and do one of the following: |
| • | Click File |
| • | Click File |
