Apply brushstrokes to paths
You can paint along a path to apply precise brushstrokes to an image. For information about applying brushstrokes, see Brushstrokes.
You can also repeat a saved brushstroke along a path. You can edit the saved brushstroke to create new effects by adjusting the size, number, angle, and color of the brushstroke.
To apply a brushstroke along a path
Back to Top
1 In the toolbox, click the Path tool .
2 Select a path.
3 Click one of the following:
Paint tool
Effect tool
Clone tool
Image sprayer tool
Eraser tool
Replace color brush tool
4 On the property bar, set any attributes for the tool.
5 Click Object Edit path Brushstroke from path.
If you want to reapply the brushstroke, click Edit Repeat brushstroke.
You can reverse the direction of a stroke by clicking Object Edit path Reverse brushstroke from path.
You can paint along a specific part of a path by selecting the area with a mask tool. For information on masking, see Define editable areas.
To repeat a saved brushstroke along a path
Back to Top
1 Click one of the following:
Paint tool
Effect tool
Clone tool
Image sprayer tool
Eraser tool
2 On the property bar, set the attributes for the tool.
3 Click Edit Repeat brushstroke.
4 In the Repeat stroke dialog box, choose a stroke from the Stroke list box.
5 Modify any attributes.
6 Click the Repeat stroke along path button .
You can load a path for the brushstroke by clicking the flyout button above the Stroke list box, and clicking Load path as stroke. Choose the folder where the path file is stored and double-click the filename before modifying the attributes in the Repeat stroke dialog box.
