You can open most bitmaps in Corel PHOTO-PAINT. Each image you open appears in its own image window.
When you open documents in Corel PHOTO-PAINT, by default they are displayed in tabbed view. You can customize the application so that documents are opened in floating windows.
You can also import images. Importing allows you to add a new image to the active image window. For more information, see Import files.
You can use the clipart and photos that are included with the application. You can search for images by different criteria, such as filename, title, subject, keyword, comment, and other properties attached to the file. For more information about searching for files, see the Windows Help. For more information, see Find clipart and other images with the CONNECT Content docker.
Open earlier versions of multilingual files
You can open or import an image from version 11 or earlier of Corel PHOTO-PAINT that contains text in a language different from the language of your operating system. To do this, you can use code page settings to ensure that object names and notes saved with the image are displayed correctly in the Objects docker. To ensure that text is correctly displayed in the image window, you need to use encoding settings. For more information, see Modify encoding settings.
To open a file you have recently worked on, click File
Open Recent, and click the filename. To clear the list of recently opened files, click File
Open Recent
Clear Menu.
You can also open an image by clicking the Open button on the standard toolbar. If the standard toolbar is not displayed, click Window
Toolbars
Standard.
You can also open a file in a new image window by dragging the file to the application window.
