PaintBrush (PCX)
The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file
Back to Top
1 Click File Import.
The File Import command lets you place the file as an object in the active image. If you want to open a PCX file as an image, click File Open.
2 Locate the folder in which the file is stored.
3 Choose PCX - PaintBrush (*.pcx) from the list box next to the File name box.
4 Click the filename.
5 Click Import.
6 Click the image window.
To export a PaintBrush file
Back to Top
1 Click File Export.
2 Locate the folder in which you want to save the file.
3 Choose PCX - PaintBrush from the Save as type list box.
4 Type a filename in the File name list box.
5 Click Export.
PaintBrush (PCX) technical notes
Back to Top
Exporting a PCX file
Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or RGB color (24-bit).
Run-length encoding (RLE) compression is supported, and the maximum image size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes.
This file format is supported in CorelDRAW and Corel PHOTO-PAINT.
Importing a PCX file
PCX files can be imported if they conform to the following PCX specifications: 2.5, 2.8, and 3.0.
RLE compression is supported and the maximum image size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes. Files containing three color planes or more than four color planes cannot be imported.
