Symmetrical patterns and orbits
Corel PHOTO-PAINT gives you tools to create symmetrical and orbital patterns.
Painting symmetrical patterns
You can paint symmetrical patterns on an image by using the radial or mirror brush symmetry mode. When you paint in radial mode, satellite brush nibs, called satellite points, create brushstrokes around a center point. When you paint in mirror mode, an identical brushstroke is created on the horizontal plane, the vertical plane, or both.
You can use the following tools to paint symmetrical patterns:
Brush tools
Other tools
Paint tool
Effect tool
Image sprayer tool
Eraser tool
Undo brush tool
Replace color brush tool
Touch-up tools
Clone tool
Healing Clone tool
Painting with orbits
You can create spiral effects by painting an image with orbits. Orbits are circular paths that rotate around a center point. Orbits let you paint spirals, pods, and rings. For example, you can draw a single spiral and adjust the size and closeness of the coils. You can also vary the size of the coils to create rounded segments called pods, or increase the number of orbits to create rings.
To paint symmetrical patterns
Back to Top
1 In the toolbox, click the Paint tool .
2 Open the Brush picker on the property bar, choose a brush category, and then choose a brush.
3 Click Window Toolbars Symmetry bar.
4 On the Symmetry bar, click one of the following buttons:
Radial symmetry — lets you add satellite points at intervals along the radius of a brush nib. Type a value in the Radial points box to specify the number of satellite points.
Mirror symmetry — lets you create an identical stroke on the horizontal or vertical plane of an image. Click the Horizontal mirror button , the Vertical mirror button , or both.
5 Click the Set symmetry center button , and click the image to position the center point for the symmetry.
6 Drag in the image window.
Click the No symmetry button on the Symmetry bar to disable the brush symmetry mode.
To paint with orbits
Back to Top
3 Click the Orbits button on the property bar.
4 Click the Orbits bar in the Brush Settings docker.
If the Brush Settings docker is not open, click Window Dockers Brush Settings.
5 Type a value in any of the following boxes:
Number of orbits — lets you specify the number of orbits that are distributed around the center of a brushstroke. Use a value from 1 to 128. Use lower values for spirals and higher values for rings.
Radius — lets you specify the distance between the center of a brushstroke and the orbits. Use a value from 1 to 999. A smaller nib requires higher values.
Rotation speed — lets you specify the speed at which the orbits rotate around a brushstroke. Use a value from 0 to 100. Higher values result in closer coils.
Grow speed — lets you specify the speed at which the orbits move toward the center of a brushstroke. Use a value from 0 to 100. Higher values increase the frequency of the size variation.
Grow amount — lets you specify the distance that the orbits move when rotating toward the center of a brushstroke. Use a value from 0 to 100. Higher values increase the size variation and create pods.
You can hide or display the point around which the orbits rotate clicking the Include center button on the Orbits bar in the Brush Settings docker.
