Set color palette properties
You can customize color palettes.
Color palettes can be either docked or floating. Docking a color palette attaches it to the edge of the application window. Undocking a color palette pulls it away from the edge of the application window, so it floats and can be easily moved around.
With color swatches, you can set the right mouse button either to display a context menu or set the outline color. You can also adjust the color swatch border and size.
To dock or undock a color palette
Back to Top
Perform a task from the following table.
To
Do the following
Dock a color palette
Click the top of the color palette border, and drag the color palette to any edge of the application window until a thin black toolbar outline appears.
Undock a color palette
Click the dotted border of the color palette, and drag the color palette away from the edge of the application window.
Change the number of rows on a docked color palette
On the palette, click the flyout button , click Rows, and choose an option from the list.
To set the action of the right mouse button for color swatches
Back to Top
1 Click Tools Options Customization.
2 In the left pane of the dialog box that appears, click Color Palette.
3 Enable one of the following check boxes:
Context menu
Set outline color
If you enable the Set outline color option, you can still display the context menu by holding down the right mouse button for at least one second anywhere on the color palette.
To customize color swatches
Back to Top
3 Enable any of the following check boxes:
Wide borders
Large swatches
You can also display color names in the color swatches by clicking the flyout button on a color palette and clicking Show color names.
