Straighten images and objects interactively
The Straighten tool lets you straighten crooked images and objects interactively by aligning a straightening bar with an image feature. After you align the straightening bar, Corel PHOTO-PAINT rotates the image so that the straightening bar is perfectly horizontal. The Straighten tool is especially useful when an image has a strong vertical or horizontal feature, such as a building or horizon.
Straightening an image: 1. Show the straightening bar by selecting the Straighten tool. 2. Align the straightening bar with an image feature. 3. Apply the rotation.
Three straightening modes are available to help you choose how the image or object is rotated. The default Auto mode rotates the image based on the position of the straightening bar. For more control, you can choose the Vertical or Horizontal mode.
By default, the application automatically crops the image after straightening to remove the edges that appear at an angle. You can choose not to crop the image but fill the edges of the image with the background color instead.
Cropped image after straightening (left); final image without cropping (right)
The straightening bar is usually adjusted by moving its handles. For greater precision, you can also specify an angle of rotation by which to rotate the straightening bar. You can also reset the straightening bar by clearing any previous rotations.
To straighten an image interactively
Back to Top
1 Click the Straighten tool in the toolbox. (This tool is located in the Crop flyout.)
A straightening bar with end handles appears on the image.
2 Drag the handles of the straightening bar to align it with the image feature that you want to straighten.
3 On the property bar, choose one of the following options from the Straighten mode list box:
Auto — automatically straightens the image based on the position of the straightening bar
Vertical — results in a vertically oriented image
Horizontal — results in a horizontally oriented image
4 Click Apply on the property bar.
You can also
Straighten a single object
Before clicking the Straighten tool, select the object.
Specify the angle of the straightening bar
Type a value in the Angle of rotation box on the property bar.
Crop the image after straightening
Click the Crop image button to enable it before clicking the Apply button.
Fill the edges of the image with the background color after straightening
Click the Crop image button to disable it before clicking the Apply button.
Reset the straightening bar
Click the Clear rotation button on the property bar.
Tip: You can also press Esc to reset the straightening bar.
You can also select the Straighten tool by pressing Shift+X.
You can also double-click the image to apply the rotation.
