Toolbox
The toolbox contains tools for editing, creating, and viewing images. Related tools are grouped in flyouts.
A small flyout arrow in the bottom-right corner of a toolbox button indicates a flyout. The last tool used in a flyout displays in the toolbox. You can access the tools in a flyout by clicking the small black arrow that appears in the bottom-right corner of a toolbox button.
Clicking the flyout arrow on the Clone tool opens the Touch-up tools flyout.
In addition to the tools, the color control area appears in the toolbox. The color control area lets you choose colors and fills.
To hide or display the toolbox
Back to Top
Click Window Toolbars Toolbox.
To hide or display tools in the toolbox
Back to Top
Click the Quick customize button , and enable or disable the corresponding check boxes.
For more information, see Customize the toolbox.
The following tables provide descriptions of the tools and the color control area.
Tools
Pick tool
Back to Top
The Pick tool lets you select, position, and transform objects.
Mask tools
Back to Top
The Rectangle mask tool lets you define rectangle editable areas.
The Ellipse mask tool lets you define elliptical editable areas.
The Magic wand mask tool lets you define irregularly shaped editable areas that include the first-clicked pixel and all adjacent pixels of similar color.
The Lasso mask tool lets you define editable areas that are irregular in shape and surrounded by pixels of similar colors.
The Magnetic mask tool lets you snap the mask marquee to the edges of areas that contrast in color with their surroundings.
The Freehand mask tool lets you define irregularly shaped or polygonal editable areas.
The Brush mask tool lets you define an editable area by brushing an area as if you were painting.
The Planar mask tool lets you create feathered masks that are defined by parallel lines.
The Smart selection mask tool lets you paint to define an editable area based on the edge of a shape or area.
Mask Transform tool
Back to Top
The Mask transform tool lets you position, size, and transform editable areas.
Crop tools
Back to Top
The Crop tool lets you trim images and straighten crooked images.
The Straighten tool lets you straighten crooked images by aligning a straightening bar with an image element.
The Perspective Correction tool lets you correct perspective distortions in photos.
The Image slicing tool lets you cut a large image into smaller sections to be used in a webpage.
Zoom tools
Back to Top
The Zoom tool lets you change the magnification level in the image window.
The Pan tool lets you drag image areas into view when the image is larger than the image window.
Touch-up tools
Back to Top
The Clone tool lets you duplicate part of an image and apply it to another part of the same image or to another image.
The Red-eye removal tool lets you remove the red-eye effect from the eyes of subjects in photos.
The Touch-up brush tool lets you remove imperfections, such as tears, scratch marks, and wrinkles, from an image by blending its textures and colors.
The Healing Clone tool lets you fix photo imperfections seamlessly by painting with sampled texture that matches the color of the surrounding area.
Liquid tools
Back to Top
The Smear tool lets you create an effect similar to dragging wet paint.
The Twirl tool lets you create swirls from specific image areas.
The Attract tool lets you reshape image areas by pulling pixels towards the brush center.
The Repel tool lets you reshape image areas by pushing pixels away from the brush center.
Effect tool
Back to Top
The Effect tool lets you perform local color and tonal corrections on the image.
Text tool
Back to Top
The Text tool lets you add text to your image and edit existing text.
Brush tools
Back to Top
The Paint tool lets you paint on an image by using the main color.
The Image sprayer tool lets you load one or more images and paint them on your image.
The Undo brush tool lets you restore image areas to how they looked before your last brushstroke.
The Replace color brush tool lets you replace the main color in your image with the secondary color.
Shape tools
Back to Top
The Rectangle tool lets you draw square or rectangular shapes.
The Ellipse tool lets you draw circular or elliptical shapes.
The Polygon tool lets you draw polygons.
The Line tool lets you draw single or joined straight-line segments using the main color.
The Path tool lets you create and edit paths.
Eraser tool
Back to Top
The Eraser tool lets you erase image areas or object areas to reveal the object or background underneath.
Drop Shadow tool
Back to Top
The Drop shadow tool lets you add shadows to objects.
Transparency tools
Back to Top
The Object transparency tool lets you gradually fade the colors of objects to reveal image areas underneath.
The Color transparency tool lets you make pixels with a specific color value in an object transparent.
The Object transparency brush tool lets you brush areas on an object to make them more transparent.
Eyedropper tool
Back to Top
The Eyedropper tool lets you choose colors from an image.
Fill tools
Back to Top
The Fill tool lets you fill areas with one of four fill types: uniform, fountain, bitmap, and texture.
The Interactive fill tool lets you apply a gradient fill to the entire image, object, or selection.
Color control area
Back to Top
The Main color swatch displays the current color, which applies to all paint, shape, fill, and text tools.
The Secondary color swatch displays the current secondary color, which is shown when you erase background areas with the Eraser tool.
The arrow lets you swap the main color and secondary color.
You can change the main and secondary color by double-clicking the respective color swatch.
The Reset color icon lets you return to the default colors — black as main color, and white as a secondary color.
