Transparency of selected colors
You can make all pixels of a certain color or color range transparent in the active object. Removing one or all of the color selection nodes makes the pixels of a certain color opaque again.
To make selected colors in an object transparent
Back to Top
1 Select an object.
2 In the toolbox, click the Color Transparency tool .
3 Type a value in the Tolerance box on the property bar to specify the range of colors that will become transparent.
If you want to blend the surrounding colors with the transparent pixels, type a value in the Smoothing box. Higher values create a smoother transition.
4 Click a color in the image window.
